Need help can I lace a 16 inch rim to a 21 inch wheel and hub??
Old 12-19-2014, 08:17 PM
Johnnie Fortune's Avatar
Johnnie Fortune
Johnnie Fortune is offline
Stage I
Default Need help can I lace a 16 inch rim to a 21 inch wheel and hub??
Hey I have a sporty 2008 and want to put a wide glide front end with a fat 16 inch rim/tire can I take the 21 inch wheel take off the 21 inch hoop and put a 16 on it with smaller spokes?
Old 12-19-2014, 08:58 PM
mustasz's Avatar
mustasz
mustasz is offline
as long as rim and hub have same number of spokes / 40 / u can do it
Old 12-19-2014, 09:00 PM
OLD 96's Avatar
OLD 96
OLD 96 is offline
Received 2,232 Likes on 903 Posts
If you are going to put a wide glide front end on it there is no need to relace your old hub. Just get the 16" wheel that goes with the wide glide front end. The problem you will run into is the neck size is different between the Sporty and the Big Twin. Or at least it used to be. Good luck.
SlimFan
12-07-2015 06:33 PM
BucksDyna11
Wheels/Tires
04-12-2015 06:46 PM
TMace
03-18-2008 06:02 PM
SOcRatEs
02-12-2008 06:34 PM
Xmedic
08-01-2007 08:44 PM
Quick Reply: Need help can I lace a 16 inch rim to a 21 inch wheel and hub??
