Adjust Clutch
Adjust Clutch
Needs some help - my clutch doesn't engage
until the lever is almost all the way out - how do I adjust it so it engages sooner. Hope everyone had a nice holiday.
Good video. I too use 3/4 of a turn and because of my aim/vpc I use an 18mm spark plug socket to tighten the jam nut with a combi wrench on the flats of the spark plug socket with a hex wrench down the hole of the socket. There are 11/16" spark plug socket out there but they are not as easy to find as an 18mm but the 11/16" fits better.
Received 4,307 Likes
Not bad, first post is how to....., not hi I from wherever and recently bought a XXXx model year xxxx. By the way, welcome to the forums.
You can adjust the free play in your cable a little. I have to do that because I have small hands, otherwise it makes maneuvering at parking lot speeds where I have to slip the clutch tough on me. Just be careful and make sure your clutch is completely disengaging when you pull the handle all the way in.
Welcome to the forum.
