Boot melted on exhaust
Old 01-25-2015, 04:01 PM
flyboyron's Avatar
flyboyron
flyboyron is offline
Default Boot melted on exhaust
The wife and I went for a ride today and after getting to our destination, I get off the bike and go around to the right side of the bike and find black rubber on the exhaust system.
I ask my wife to check her boot and it is partially melted. She said she was stretching her leg and letting it hang down for a while, and I guess it was rubbing against the pipes.
How do I get this off now without scratching the pipes?
Old 01-25-2015, 04:08 PM
HDmikie's Avatar
HDmikie
HDmikie is offline
A buddy used Easy-Off oven cleaner with good results. I think the sooner-the-better. The more you ride, the more you'll bake on the rubber. JMO
Old 01-25-2015, 04:13 PM
nhrider1's Avatar
nhrider1
nhrider1 is offline
+1 on the easy off. It works best if the pipes are warm.
Old 01-25-2015, 04:23 PM
EP50's Avatar
EP50
EP50 is offline
Old 01-25-2015, 04:41 PM
r1cochet's Avatar
r1cochet
r1cochet is offline
What works for me:
1. When hot, use a thin, flat piece of wood to scrape as much soft residue off.
2. Once cooled-down, use 000 steel wool with a solvent such as goof-off to remove the remaining residue/stain.
Old 01-25-2015, 04:50 PM
upflying's Avatar
upflying
upflying is offline
Received 26,483 Likes on 11,210 Posts
I guess that's one way to burn rubber.
Also suggest moderate use of a propane torch or heat gun to soften the goop as you scrape.
Old 01-25-2015, 04:59 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,974 Likes on 17,496 Posts
Taken fresh rubber & plastic off hot pipes with a cold really wet towel , haven't lived till somebody's plastic cover tarp comes off the pickup and you can't dodge it , friggen melted plastic everywhere. Get the bike hot let it idle and get a normal sized towel with a bucket of cold water, drunk the towel and wipe , knock the chunks off the towel and repeat till it's gone. Chrome cleaner for finish work.
Old 01-25-2015, 05:08 PM
labou1's Avatar
labou1
labou1 is offline
Default melted boot on exhaust
Easy off oven cleaner, make sure they are cold, cover all other items, spray, leave over night, hose off
Old 01-25-2015, 05:28 PM
baka1969's Avatar
baka1969
baka1969 is offline
If you use Easy Off make sure you spray it on a towel and apply it to the pipes using the towel. Easy Off WILL ruin your painted surfaces. It's not worth it to "try your best" not to get overspray all over the place.
Old 01-25-2015, 05:44 PM
trckdrvr's Avatar
trckdrvr
trckdrvr is offline
Im guilty..not sure how I did it.
but I discovered black residue on my pipes after a ride.
then discovered a melted spot on heel of my right boot.
Quick Reply: Boot melted on exhaust
