Baffled by Baffles-
Baffled by Baffles-
I removed the exhaust tips off my 3 1/2 inch Screamin Eagle slip on's to replace them with some new one's. Just for S&G I removed the baffles, and am now wondering can I or should I drill these puppies out a bit for a little better sound? Pro's & Con's welcomed and GO-
I've had screamin eagle exhaust on 2 or 3 bikes and what I did was take the baffles out and drilled all the holes bigger. On mine, when I took the baffles out, inside the muffler shell was a metal tube with holes drilled in it and between the that metal tube and the muffler shell was fiberglass wrapped around the metal tube. I used a long screwdriver and hammer and knocked the metal tube out with the fiberglass also. I left that out and put the baffles back in with the bigger holes. Didn't notice any difference in performance but they have a better, louder/deeper sound.
It really doesn't matter what we think, what do you think? Did you like the sound and performance before taking the baffles out? Did you want more noise? It's all about personal preference, but I don't like a LOUD exhaust. A nice rumble, sure, but not the drag pipes or mufflers with baffles removed. But hey, that's me. I have SE slip on's on my bike and I really like them. Just the right tone without being offensive (in my opinion).
Do what you want, not what other people want.
Below is link where you can see more information.
http://www.dkcustomproducts.com/Thun...nserts_c57.htm
Also included is a video of five different bikes with Thunder Torques to let you hear how the sound.
Kelsey
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
Cristy
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
If your looking for a bit more sound and performance, then add a few more holes. Your performance will increase. If you run no baffles, performance will suffer at a certain rpm. Drag pipe lag, sound waves in your pipe traveling up and down the pipe will eventually match the opening of your exhaust valves. Performance suffers until your engine can over take the sound pulse. Baffles silence the pulse therefore performance gain. Me, I like loud pipes. Is it worth the loss in performance, sometimes. Some say you don't loose performance from drag pipes, but on every dyno run I've seen, you can see the lag. I know guys that have added a dozen or so holes in theirs. Very noticeable gain in power and sound.
