Vinyl Wrapping Questions
Old 02-12-2015, 05:14 AM
Brian_Reale's Avatar
Brian_Reale
Brian_Reale is offline
Default Vinyl Wrapping Questions
I have seen a few threads about this but I haven't gotten an answer to a few specific questions I have, Anyone out there have any DIY experience with wrapping your bike?
1. Does heat effect the wrap? I want the tank wrapped all the way around, is it a problem that it is sitting within inches of the engine? Heat is used to apply the vinyl and make it pliable, how does heat from the engine not loosen up your hard work?
2. Do i need to seal the edges of the vinyl with something?
3. Do I need to laminate the wrap? Im using 3m 900 series vinyl, they claim that it comes with a clear protective laminate integrated with the vinyl. Is it an industry standard to use this AND a separate laminate
Info from anyone with experience would be appreciated, info from anyone in the industry (graphics / vehicle wraps) would be cherished.
Old 02-12-2015, 09:18 AM
Muttleybass's Avatar
Muttleybass
Muttleybass is offline
1. Regular heat, like from the heads should not affect the wrap. However, it's not like paint. The vinyls they use nowadays are very pliable and can get soft under very hot conditions. In other words, when it's hot, don't pick at it, but it should be fine. Unless it's really close to the pipes.
2. No edge sealing required.
3. The vinyl itself is the same vinyl that they cut up for pinstriping or stock graphics at the factory, so non-printed vinyl does not need laminating. When printed, different printers use different inks. It used to be that the printed graphics always had to be laminated, but with wraps becoming more popular, better inks have been developed along with vinyl specially for vehicles. If you're printing, the shop should provide the wrap with any laminating required.
Hope this helps.
Mike
Vital Signs Ltd.
ARNAV (08-23-2020)
Old 02-12-2015, 03:26 PM
SD lumpy's Avatar
SD lumpy
SD lumpy is offline
Why don't you have it dipped
Old 02-13-2015, 03:33 AM
Brian_Reale
Hope this helps.
Mike
Vital Signs Ltd.
Thank you very much, very helpfull
Old 02-13-2015, 03:38 AM
Brian_Reale
I wanted to keep this as low cost as possible, I can get the vinyl for cheap through someone and this way I can (at least attempt) to do it myself.
ARNAV (08-23-2020)
Old 02-13-2015, 07:19 AM
scott01's Avatar
scott01
scott01 is offline
plastidip is a cheap alternative as well and doesn't require a lot of skill. You can also get it in several colors
Old 02-13-2015, 11:48 AM
Pumba11's Avatar
Pumba11
Pumba11 is offline
Here you go...PlastiDip
ARNAV (08-23-2020)
JoeG92softail
Exhaust System Topics
12-27-2010 02:21 PM
bucket13
08-28-2010 12:28 PM
motordrum
03-04-2010 06:53 AM
twhill3
08-09-2009 08:47 AM
piggy
06-09-2007 09:40 PM
Quick Reply: Vinyl Wrapping Questions
