wax
Old 02-21-2015, 08:49 AM
Joe Dirt 14's Avatar
Joe Dirt 14
Joe Dirt 14 is offline
Default wax
If you paste wax your bike. Is it ok to use spray on waxs like lucas makes on top of that? or should you just stay with the paste wax? I also find that using pledge works good. I got that from you guys on the forum. but my main question is it good or bad to use spray waxes over your paste waxes.
Old 02-21-2015, 08:58 AM
Geoff's Avatar
Geoff
Geoff is offline
I've used Meguiars paste wax and a detailer spray many times with no problem. My only advice is to avoid products like Johnson paste wax. It's made for furniture, not paint.
Lots of folks use Pledge. I don't because there are purpose made automotive products that do a better job.
Old 02-21-2015, 09:42 AM
DresserDude's Avatar
DresserDude
DresserDude is offline
you sure can spray products over top of your paste wax. Don't forget, we have a great detailing section in the forum.
Old 02-21-2015, 12:32 PM
Bone Doc's Avatar
Bone Doc
Bone Doc is offline
Received 10,857 Likes on 4,111 Posts
What would happen if you use Johnson paste wax on paint? Pledge is made for furniture as well, not paint and it works very well.
I use Pledge on occasion. It cleans the dirt off and leaves a shine behind comparable to any wax. What criteria are you using that would make an automotive product do a "better job"? It's clean and shines. Because a product is specifically marketed for use on automobiles doesn't necessarily make it better.
Products for furniture are not used directly on the wood. It's on the varnish or polyurethane finish. Same for automotive products. They are formulated to work on the clear coat finish, not the paint itself. I'm sure car waxes would shine furniture quite well without harming the finish just like furniture products (eg Pledge) work fine on vehicles paint.
Old 02-21-2015, 12:37 PM
pretz's Avatar
pretz
pretz is offline
It isn't called Quick wax for nothing. Keep shiny my friend.
Old 02-21-2015, 12:51 PM
oct1949's Avatar
oct1949
oct1949 is offline
I've used Lucus slick Spray mist between wax's for yrs,,
Old 02-21-2015, 12:53 PM
Cobra1's Avatar
Cobra1
Cobra1 is offline
Received 1,289 Likes on 523 Posts
Same here, love the stuff. I use it after a wash as it makes the water just run off
Old 02-21-2015, 02:46 PM
Bone Doc's Avatar
Bone Doc
Bone Doc is offline
All wax will make water run off. That isn't a special property of Lucas Slick Mist.
Old 02-21-2015, 02:54 PM
upflying's Avatar
upflying
upflying is offline
Received 26,042 Likes on 11,062 Posts
Wax is like your choice of motor oil. Everyone has opinions, use what you like, it's all good.
Old 02-21-2015, 03:27 PM
gomiller2's Avatar
gomiller2
gomiller2 is offline
Good old turtle wax paste
Quick Reply: wax
