Repairing a Vinyl Backrest
I have a small hole ,about as big as a tip of a pencil lead.I have seen some 3M products that they sell in autoparts stores,but I wonder if they work.The repair doesn't have to be perfect.Any advice?Thanks
If they work... problem solved. If they don't, then you're no worse off. What choice do you have?
This should give you ideas: Vinyl Repair Kits
I had a Tour Pac backrest with a small hole in it. I bought a kit from Walmart after reading reviews on many kits. It is better than what it was, but if you are looking for it you can see the repair. It looks better than the white backing against the black vinyl that was showing before.
I have a small tear in my seat at the right edge bottom, about 1/2'' frow wear. You could see the white backing making it stick out more.
What I did was use a Black marker on the backing and now its barely noticeable.
bjewell
06-28-2011 12:40 PM
