Removing primary chain
Need some help. Can you remove the primary chain from the compensator sprocket without removing the clutch or even removing the chain from the clutch? I'm wanting to change to the SE comp but don't want to remove the clutch. I've heard different answers so I'm not sure. thanks for any help.
Its a 2007 Softail Custom....
Chain, clutch and compensator are removed and installed as a complete system. All 3 must come off.
thanks guys. I thought you could pull it without removing the clutch. Just wanted to make sure. I searched youtube but only found a couple installation videos.
............ go to the Primary/Driveline/Clutch section. The clutch and and comp need to be removed and depending on your expertise, the inner primary as well. Be mindful of the reverse threading on the clutch nut - buy a manual and ensure that you have the correct tools.
IndianHarley
12-12-2020 06:13 PM
OneBlackFly
09-13-2007 12:48 AM
20NightTrain03
06-05-2007 08:44 PM
