having a hard time shifting with new boots
I decided to get some new boots for better protection than the shoes I have been practicing with. I'm having a hard time getting the front of my foot under the shifter. Is there a way to adjust the shift lever or do my feet just need to adjust?
You loosen the bolt that holds the shifter on the shaft, remove the shifter and reinstall it higher. I've never done it on a HD but it worked on dirt bikes and a Yamaha street bike I owned and figured it ought to be the same on HD, though I am far too lazy to get up and look right now
I moved mine up when I first got my bike because it felt like it was crowding my foot but I moved it back to where it was. I still sometimes feel like I could move it up a little.
there's 2 ways to adjust it. the one way is to remove the lever and move it a spline. if you need a finer amount of adjustment, then you can adjust the length of the rod between the front and rear levers. loosen the nut, take the head off the lever and spin it to lengthen or shorten. then put the head back on.
Loosen the bolt and move it up a few splines till you find your sweet spot then tighten it back down. Ever since I was a kid riding dirt bikes, I have always set the shift lever to ride just above my boot with a little gap when my foot is resting on the peg. I use the same boots all the time so it's always the same. I use mid controls and this is the best setup for me.
Set up: Taylor your bike to fit!
Heel shifter: I always thought the heel shifter was to protect my "Street shoes" from scuffing. I have removed my heel shifter, and enjoy the extra room on my foot board.
