Stand back........I'm goin' in!
Decided I didn't want to be shackled by the stealership or even an Indy shop so I'm going to do my own 10k service. After reading all the posts here and watching a couple of YouTube videos, it seems easy enough. I had to buy a couple of tools (to take the rear passenger footrest off and the torx socket to get the primary cover off)......$1.97 each at Home Depot. The rest seems pretty simple.....lots of inspection. I likely won't adjust the clutch because it seems to be within the specs already. I'll replace the oil plug gasket and the primary ring and buy the fluids at the stealership. Anything else that might be a gotcha?
It's pretty easy! Sounds like you're getting it nailed down. About the clutch though, adjust it this time so that you know how to do it and how simple it is for future reference. Also, do it now because, while you believe it to be within spec, you may have just gotten used to it while it became out of spec and that's why you think it's fine. You may find out it's better after you've done the adjustment.
Ride Safe -Ride Smart
"He Who Lives In Joy Does His Creator's Will".
The Baal Shem Tov, Founder of Chasidic Judaism... ca 1750's
It's no big deal. With a few tools and the manual, you'll be done in a few hours.
Just take your time and make a morning out of it. I find it quite relaxing.
Lots of threads on here, where people take the wrong drain plug out. Make sure you know the right one. Be careful not to hit the crank position sensor, when taking the filter off.
