Oil filter 13 FLHTPI
decided to do the 1k break-in fluid change on my Electra glide. what the hell kind of wrench do I need to get the oil filter off? it is buried between oil cooler lines and primary sensor. I tried the HD end cap type with the cut out for sensor, filter too tight ( wtf do they use at York to tighten them on ? )....it just rolls right off the filter contours. went to NAPA and got a close quarters 3/8 ratchet type, wont fit....I have been given several radical methods to get it off,. but what do I use to install new one, other than ordering a K&N 3/4" lug type filter.
I use the HD one with the cut out to remove and replace. 3/4 turn after contact with the gasket. I've never had trouble removing a filter that I put on, but the MOCO and the dealer use a little more force I guess.
If you can get another set of hands, get one on the strap wrench and one on the HD end cap wrench. Once you've moved an inch or so it'll come off.
Otherwise you can do the old drive a screwdriver through the filter trick...But I would still have another person cranking on the end cap filter.
The K&N filters do make life easy.
I have used channel locks, and extended head pipe wrench, strap type filter wrench, and when really stuck....a screwdriver right through the sides. Sorry you are going through this from the factory. When you finally get it off make sure you check the adapter where the filter spins on. It may loosen up on you and will leak later. You can tighten it with the head of a 1/4 inch bolt or find a hex to fit it. I think its a 7/16th hex.
Only once have I run across a filter so tight that the cup type filter wrench slipped under force. What I did was place a couple of shop paper towels over the filter first and then tapped the socket on. This provided a more snug fit and I used a breaker bar for extra leverage. This method broke it free but damn it was tight. This was on a used bike I purchased and I'm guessing someone installed the filter dry (maybe even with tools?) without a smear of oil around the o-ring first. Give this a try.
