Power Vision
Power Vision
Ok.....don't have the $4200 to cam my bike. Going to tackle it myself. Which is not good! Lol!
Watched J & P cycle video. Going to do a 555cam or similar.
Have some questions about Power Vision product.
Seems as though you plug it in and let it do its thing. $450 some odd dollars. For the extra $450....can go wideband. Is it worth it? Also once the cells are filled I assume this unit is removed? And if I decide to do more work to bike. I just plug it in and play some more.
So......is the extra wideband setup worth the dough? Or is there something better for the money. That I can look into.......
Thanks guys!!!!
Thanks guys!!!!
Yes you can remove it after you have finalized and flashed in the tune you want. Or, you can leave it on and set it up to show the gauges of your choice. I use the wideband tuning feature and it's worth it to me. Might be because I'm a gearhead and like to tinker. You can try it with just the narrow bands first and see if you are happy at that level.
My question is who in the hell quoted you $4200 to change cams? That's effin' ridiculous! Should be able to get it done 3 or 4 times for that amount.
Received 47,790 Likes
Thanks guys!!!!
Thanks guys!!!!
With the Power Vision you do just plug it in and basically let it do it's thing
The Power Vision is delivered to you with a Custom Map, for Your Bike, already installed in it. You can plug it in, load the new tune into your bike, unplug it, and be riding with the New Tune in 5 minutes.
After it is installed you can remove it or you could mount it to your handle bars.
Wideband, some people would say it is worth it then some would say it isn't.
You can always do a auto tune after you have the Power Vision installed and that will get you an almost perfect tune.
Hope this helps you out
Kelsey
__________________
Cristy
FREE SHIPPING - ORDERS OF $100 OR MORE - LOWER 48 STATES
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
Cristy
www.DKCustom.com
Call: 662-252-8828
Text: 662-420-4891
