Won't crank over
Old 05-10-2015, 09:32 AM
Ultraman43's Avatar
Ultraman43
Ultraman43 is offline
6th Gear
Default Won't crank over
Recently, I put a 103 engine in my 2004 Ultra Classic, now it appears I have a intermittent problem with the bike. Sometimes when I shut it off to refuel or after it is shut off for some other reason it cranks over real slow & won't start, this don't happn all the time. Battery is only 2 yrs. old & checks out fine, I checked the battery connections and there tight, would really appreciate any suggestions on what could be the problem....Thanks
Old 05-10-2015, 09:41 AM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is online now
Received 1,811 Likes on 1,064 Posts
Does the ECM in your bike have the capability to recognize the ACR's that the 103 has and if it does are they activating?
Old 05-10-2015, 02:17 PM
Bingee's Avatar
Bingee
Bingee is offline
The 2004 ECM's do not have ACR capability. Unknown if the OP's engine even has ACR's. He didn't say.
Old 05-10-2015, 08:29 PM
Slow Road's Avatar
Slow Road
Slow Road is offline
Did you check the battery cables at both ends and not just at the battery?
Old 05-10-2015, 09:06 PM
Unbalanced Bob's Avatar
Unbalanced Bob
Unbalanced Bob is offline
I was under the impression that all the 103 engines have ACR. Of course, I've been wrong before.
Old 05-10-2015, 09:16 PM
OldEnuf2NoBtr
If the OP doesn't have them activated somehow, you'll need to install a manual set of ACR's or pony-up for a set of S&S Easy Start cams.
Old 05-10-2015, 11:03 PM
Bingee's Avatar
Bingee
Bingee is offline
A factory 103 would have them. But if he has a big bore 96 to a 103 he may not.
Old 05-11-2015, 11:13 AM
Very High Plain Drifter's Avatar
Very High Plain Drifter is offline
It definitely does sound like a problem with the ACRs though.
+1 if it's a Bog Bore kit rather then factory.
MX Mark
2014-2023 Touring Models
22
05-11-2020 09:29 AM
MCarbonaro
07-02-2013 07:06 AM
igloorider
08-13-2012 10:41 PM
BadMetal705
12-23-2011 02:18 AM
blight
10-05-2007 08:23 AM
Quick Reply: Won't crank over
