Turn signals
Old 05-10-2015, 07:48 PM
Irv775's Avatar
Irv775
Irv775 is offline
Default Turn signals
Finally figured out where to post my Q.
SO; I've got a 2004 1200 Custom Sporty. The front Turn signals work. The fronts work with flashers turned on. But the rears do not. The rear flashers do not work either. I checked the rear bulbs and they are good. Fuses are good.
Any ideas? I can't see this as a big problem but if you don't know what to do, it's a huge problem. Thank you.
Old 05-10-2015, 11:33 PM
desertclassic's Avatar
desertclassic
desertclassic is offline
Pull the seat and look at the harness connectors and make sure they are snapped together. It doesn't hurt to unplug and plug. If that doesn't do it, check the wiring that goes under the fender to the turn signals. There is probably a covered wire and the wire has been known to unplug or break. Hope this gives you a start.
Old 05-11-2015, 12:56 AM
Irv775's Avatar
Irv775
Irv775 is offline
Right on, thanks for the help. I'll try, or start there.
Old 05-11-2015, 06:51 AM
14GuineaPig's Avatar
14GuineaPig
14GuineaPig is online now
Get yourself a test light or multimeter and start checking at the connector under the seat and go from there.
Old 05-11-2015, 08:07 AM
rizzo's Avatar
rizzo
rizzo is offline
Received 4,619 Likes on 2,094 Posts
I seem to remember a similar thread a while back but it was for EVO's. https://www.hdforums.com/forum/evo-c...ker-fluid.html
Old 05-11-2015, 01:01 PM
hemisportster's Avatar
hemisportster
hemisportster is offline
I have a friend who is having the same problem with a 2005 Ultra Classic that has a trike kit. The front blinkers work fine but the rear do not blink. Perhaps we can exchange solutions to the problem once we find them.
Old 05-11-2015, 01:09 PM
Irv775's Avatar
Irv775
Irv775 is offline
Sounds good
Old 05-14-2015, 07:13 AM
Irv775's Avatar
Irv775
Irv775 is offline
I've checked the channel under the fender, looks great. Under the seat, the connections are solid. Baffling! I just can't figure it. I can ride with hand signals but not as safe as lights. I don't want to not be seen and hit eh? Thanks for everyone's a help!!
TPost
EVO
11-21-2016 11:53 AM
jackalsilva
Electrical/Lighting/Alarm
06-21-2016 04:23 PM
75hdxlh1000
Ironhead
05-12-2013 07:30 PM
Krazy8s
06-02-2011 02:15 PM
DR. V-TWIN
10-15-2010 09:23 PM
Quick Reply: Turn signals
