right side shifter
Not knowing the reason why you ask.
Other than a historic Harley originally built w/ right side shifter....
Maybe you could fabricate linkage. Would require welding brackets to the frame I would suggest. And be aware if the linkage was run under the engine, the linkage would be susceptible to damage from speed bumps and all.
I believe classic Norton Commandos are right side shift.
I for one would like to know your plans.
http://www.b-brightsideshifter.com/
I almost agree with this, except it does not take that long. Used to jump back and forth between my Bonneville and Panhead without even a thought.
Actually the adapt is/was pretty easy,, you'll forget a time or two and drop a gear instead of braking,,
