Fluid Change while on Jiffy stand
Is it absolutely necessary to have the bike upright to change and add the proper amount of fluids back in all three places? Seems like just adding the amount of each fluid that the manual states should be good?
If so is there a reasonable priced option for a 2015 Ultra Limited? I have looked at the choices but have no experience with them and don't want to dump the 900 lb. bike in the garage!!
I just don't have ~$1000.00 for a nice bike jack.
Thanks.
Thanks.
You can swap fluids w/o jack or lift...get a wheel stand/chock to level bike and let 'er rip.
http://www.harborfreight.com/1800-lb...ock-61670.html
I change all the fluids on the side stand, can't think of a single reason why you can't too. You don't need to level the bike for the primary fill either, get one of the orange primary fluid funnels from your dealer, thats all you need. Drain and fill on the side stand, HD made it that way. No Problemo
You mean HD did engineer something right??? Don't let most of the forum hear that!!
I just double checked my manual, Doesn't say anything about standing bike straight up. Iv'e always done it on the jiffy/kickstand. Positions the Oil and Primary drain plugs at their lowest piont. Tranny drains so clear and clean when I do it, I don't worry about draining every drop.
Agree with the post above.
Crankcase oil -- leave bike on sidestand. Dealing with the oil filter is the hardest part.
Transmission -- I leave the bike on the sidestand for this, too. The manual calls for 32oz, so when I refill, I just pour a full bottle in and close it up.
Primary -- I set the sidestand on a brick, which -almost- puts it upright, but not quite. It's still leaning a couple of degrees to the left. I drain the primary and then pour 38oz into it, and close it back up. Just be careful with it while it's "up on the brick"...
When mine is on the jack, I cannot place my drain pan where I need it, the jack is in the way. So even with a jack, I change my fluids on a 2X6, which is a whole lot cheaper than a jack.
