Front break lever all the way to grip
Old 07-14-2015, 11:52 AM
mandd71974's Avatar
mandd71974
mandd71974 is offline
Default Front break lever all the way to grip
I just changed wheel on my 2010 ultra to wheels from a street glide. (Too darn hard to clean) Now my brake lever on the 1st pull comes all the way back to the grip. The second pull is fine. I changed out all of the brake fluid and bled the brakes and it still does it. The rotors are the same size, so any solutions? Thanks
Old 07-14-2015, 11:55 AM
RHPAW's Avatar
RHPAW
RHPAW is offline
Received 13,783 Likes on 6,213 Posts
You aren't done bleeding it.
Old 07-14-2015, 11:59 AM
mandd71974's Avatar
mandd71974
It was doing it when I changed the from rim before bleeding the breaks.
Old 07-14-2015, 12:01 PM
mandd71974's Avatar
mandd71974
I must admit, I didn't check the condition of the pads when I changed wheels. After inspecting with a flash light, the inner pads do look more worn than the outside. Could worn pads cause this?
Old 07-14-2015, 12:03 PM
roadking2000's Avatar
roadking2000
roadking2000 is offline
Bleed them again. I don't think you did a good enough job bleeding them the first time around since you said you changed out the fluid. When I think I'm done bleeding my brakes, I usually bleed them one more time after that just to be sure and you should check your fluid level again. There really isn't much to go wrong unless you took everything apart. If all you did was change fluids, bleed them again and see where your at then.
Old 07-14-2015, 12:12 PM
mandd71974's Avatar
mandd71974
When I put the new rim on is when it started. I only changed the fluid after the grip started coming all the way back. I didn't change anything or do anything to the caliper when I changed the wheel. That's why I cant figure out why it all started with the rim change. All I did was undo the calipers and hang them off the handlebars and re-install them when the rim was changed.
Old 07-14-2015, 12:13 PM
roadking2000
I doubt if the pads themselves caused the problem. They aren't going to self correct in one pull of the lever and all of a sudden work after bottoming out on the first pull. Check your pistons and clean them if necessary. They may be sticking although I don't have a clue why the brake lever would bottom out if they are. If nothing else, cleaning the pistons isn't going to hurt a thing and may help and it's free.
Old 07-14-2015, 12:15 PM
mandd71974's Avatar
mandd71974
That's what I'll try. It doesn't make sense to me either. The brakes worked fine until I changed the rim. Thanks
Old 07-14-2015, 08:17 PM
Trucky911's Avatar
Trucky911
Trucky911 is offline
Change the pads. I put a cheap set of pads on my 02 Flhtci, 2000 miles later the lever was bottoming out. Bled the lines and still bottomed out. Put new Harley pads on and no more problem.....
Trucky911
Old 07-14-2015, 09:37 PM
Iarecobra's Avatar
Iarecobra
Iarecobra is offline
Very possible that it's time to rebuild the master cylinder.
Quick Reply: Front break lever all the way to grip
