Bars Extension on 2013 Dyna Wide Glide '2' or '3'
Hi guys, I want to extend my bars on my 2013 wide glide.
Apparently the 2 inch extension works good, I was wondering if I can go 2.5 or 3 without changing any cables?
Also if anyone has picture of wide glide with risers would be nice
Thank you
Thank you
I went with DK Custom 2" riser extensions on my '13 Wide Glide, in looking at the brake line it appears that there's just enough to make a 3" extension. You won't have any problems with the throttle, clutch, or bar wiring, it's the brake line that's close but I do believe you can do it; 2.5" won't be a problem, installing the risers is a rather easy install. I also replaced the rubber bushings for solids when I did the extensions.
A couple of images, the 2" extensions along with the 2" tank lift gave me what I was after
Edit: These are the riser extensions I used: http://www.dkcustomproducts.com/2-In...2-SFT-RSRS.htm
SoftailBrian
07-14-2006 05:53 AM
