Engine temperature sensor
Old 07-20-2015, 10:19 PM
Dcampri's Avatar
Dcampri
Dcampri is offline
Default Engine temperature sensor
Has anyone experienced the P0117 code for an engine temperature sensor low voltage? Hot day with traffic, engine light went on and bike began to run a little rough at idle. The above code came up on running the diagnosis. Of course Harley dealership can't take the bike for a week. Thought of swapping out et sensor but thought better to leave it to the pros.
Old 07-21-2015, 07:00 AM
ConfuciusSay's Avatar
ConfuciusSay
ConfuciusSay is offline
Received 2,528 Likes on 683 Posts
I had a rough idle/stalling issue when the bike was hot. I did not get any codes, but I did change out the engine temperature sensor. It took all of about 25 minutes (that includes gathering tools). If you have a service manual and basic skills and tools, it's an easy fix. I got my replacement sensor on line from Dennis Kirk. About 30 clams.
Good luck.
Old 07-21-2015, 07:02 AM
carlgrover's Avatar
carlgrover
carlgrover is offline
Received 2,187 Likes on 1,264 Posts
I have a Fuel Injected EVO that likes to eat engine temp sensors about every 20k miles. If the code says the ETI is bad, I would just buy another and replace it. It's an easy 1 beer fix on my Road King.
The pros are gonna charge you about 1-2 hours labor to do the job. You could get quite a few lap dances for that coin.
carl
Old 04-27-2019, 08:33 PM
ozzie21's Avatar
ozzie21
ozzie21 is offline
I agree. Just change the sensor. They only cost around $30-$40 and should only take a few minutes to change. The dealer will charge you at least 1 hour labor and the price of the sensor. I would guess they'd charge you also some minimum to hook your bike up to the ET (Electronic Technician). And since they can't take your bike for another week it sounds like the best course of action.
Old 05-02-2019, 04:36 PM
ozzie21's Avatar
ozzie21
ozzie21 is offline
I had an issue this year with both my engine temperature sensor and my TMAP sensor. My bike when cold would start OK and seem to idle OK but within a few minutes of getting on the road it would start running really rough, would not idle and often just shut down and also when running it would hunt with RPM surging high then low and high and shut down. I was getting error codes P0117, P0118 & P0113. The P0117 & P0118 have to do with the engine temperature sensor and the P0113 is related to the TMAP sensor. I changed my engine temperature sensor and went for a test ride and it was still acting up. I checked my error codes. No more P0117 and P0118 error code but I still had the P0113 code (TMAP sensor). I checked under the wiring looms and found one of the 3-way soldered connections where one of the wires branched off to the TMAP sensor had vibrated and broken off at the wire going to the TMAP sensor. I added a short length of wire and soldered everything back and shrink tubing all the bare connections. I already had a new TMAP sensor so I swapped out the old one for this new Fueling TMAP sensor. The old TMAP sensor was likely OK but being in there for 8 years I figured may as well change it. Went out for another test ride and now my 120R Trask Turbo FLHX is back to running smooth and strong like it always did. And no more error codes. I see there's also a thread here about TMAP sensors. I'm going to post most of this text there with a couple of pics.
Old 05-02-2019, 08:42 PM
Jehu's Avatar
Jehu
Jehu is offline
Received 1,073 Likes on 609 Posts
Good on you for your successful efforts but...
OMG,
Gimme a carbed Shovel over this crap!
Old 05-02-2019, 10:29 PM
ozzie21's Avatar
ozzie21
ozzie21 is offline
OMG,
I know what you mean. I've got a '74 FXE also..... You've got to get your head into a different space (put a different hat on as they say) going from one to the other when you're troubleshooting.
1Fordman (05-02-2019)
Old 05-02-2019, 11:11 PM
1Fordman's Avatar
1Fordman
1Fordman is offline
Ozzie71, Your 74 FXE has got to be one of the most awesome shovels on the planet! I'm building a 72 FX into an FXE, if it's half as nice as yours, will be a happy camper.
WoodButcher66
2014+ Touring Models
05-31-2021 06:08 PM
txphatboy
13
05-20-2018 09:40 PM
neilwhittal
Engine Mechanical Topics
08-07-2017 12:26 PM
WindowMan
EVO
16
07-23-2017 02:10 PM
rtbassmaster
Exhaust System Topics
05-09-2013 07:14 PM
Quick Reply: Engine temperature sensor
