Noob riding questions
I've had my Sportster XL1200C for about a week.
1 - Gear selection
In a car, it's quiet. If it's revving, it's because I'm going up hill or I forgot it's in manu-matic mode. Otherwise, quiet. On the Sporty, which has Cycle Shack pipes, it's never quiet, lol. In my community the speed limit is 25mph, and 2nd gear is where I stay. If I go to 3rd, it lugs. On my local county road with 40mph limit, 3rd it about as high as I go. My brain is telling me to upshift, I guess because of the noise. Does it sound like I'm in the right gears for the speeds mentioned? I don't have a tach. I don't think the RPMs are high, but I'm just not used to riding for miles in lower gears.
2 - Turning technique
I need to improve on starting a turn from a stop. For right turns, I'm leaning the bike slightly and turning the bars while stopped, so I can make the tighter turn. But once I get going the front wheel wants to go back to straight too soon, and it's making me turn wider than I want. Part of it is my need to improve my balance when starting out. Any tips? Should I be using some back brake on these starts?
1 - Gear selection
1 - Gear selection
1 - Gear selection
2. This is where parking lot practice (aka PLP) comes into play. That technique you mentioned takes time to get comfortable with. I tend to just start slow and drag my rear brake a bit as if I was making slow speed maneuvers. Either way, practice in a lot and it will eventually click. The technique you mentioned is shown here
When I took the (equivalent to) MSF course the instructors taught us a technique you can try: when approaching a stop where you must make a sharp turn, "pre-turn" your bike by angling it in the direction you want to turn before stopping.
This works well in on-the-road situations but obviously won't in a crowded parking lot so you still need to practice the techniques already mentioned. Good luck!
