When does a Harley STOP being a Harley?
I've been working on rebuilding this '96 Road King, and piece-by-piece, I've replacing original factory parts with stronger, more modern-engineered pieces. In not so long from now, I'll be down to a couple of tins, the frame, the motor, and the transmission as being the only factory parts left on it. Eventually, I plan on replacing the motor and trans, leaving only a few polished scraps of metal and the frame as being OEM parts.
So, when, at what point, does this bike cease being a Harley and become an original creation?
Almost anyone can make a fender or frame. With the right tools you can weld brackets and assorted do dads.Forks and rims are available from aftermarket companies. Wires are non brand components. If your handy, you can make your own seat. There are replacement motors and transmissions available from american and foreign sources. But,a real Harley motor is only made by The Harley Davidson motor company. That is what makes a Harley, a Harley. If you had the ability to make a motor from scratch, you would probably give it your name, because Harley Davidson is a registered trademark for their motor.,,,
Dealership I use describes this as a Nightrain based Chopper, the only parts of a Nightrain left are probably the innards of the engine and gearbox.
http://www.lindhd.co.uk/pages/used/u...d3faef318a.htm
