my sftl twin cam backfired & now won't start
Old 09-05-2015, 01:27 AM
Big Isle rider KC's Avatar
Big Isle rider KC
Big Isle rider KC is offline
Stage I
Default my sftl twin cam backfired & now won't start
my '06 softail backfires on startup sometimes, this last time it made a loud pop
then, ran like it was running on 1 cylndr. after changing plugs & intake seals, it has spark 2 the plugs. It turns over staters fine -just won't kick or fire. chckd module, coil, fuses, carb is fine. Don't know what else 2 do. Anybody had the same experience or ideas 2 fix this problem?
Old 09-05-2015, 05:47 AM
Iron lHorse's Avatar
Iron lHorse
Iron lHorse is offline
Received 2,365 Likes on 1,157 Posts
Do you have spark at each plug ?
Are you getting gas to the cylinders?
When you turn the start switch to on do you hear a short hissing sound for 3to 5 sec.?
Did you check for a loose battery cable ?
Loose intake manafold clamp carb to motor ?
Could also be bad gas .
Old 09-05-2015, 12:02 PM
rideflhr's Avatar
rideflhr
rideflhr is offline
I doubt his "CARB" bike is going to be doing much hissing.
Old 09-05-2015, 12:42 PM
jakas66's Avatar
jakas66
jakas66 is offline
x2 on that
Old 09-05-2015, 01:37 PM
TwiZted Biker's Avatar
TwiZted Biker
TwiZted Biker is offline
Received 47,899 Likes on 17,470 Posts
BIke needs 3 things to start , gas so make sure it's getting to and through the carb, spark so check the plug wires and plug gaps again, last is compression and while your at it maybe try the kill switch, not joking there you'd be very surprised how often that happens.
It has those there's no reason it shouldn't at least try to fire.
Old 09-05-2015, 02:36 PM
Iron lHorse
True , He can skip the fuel pump hose failure thing. Thanks
Old 09-05-2015, 04:58 PM
the blob's Avatar
the blob
the blob is offline
I'd next check crank sensor and battery cables. Are you getting fuel to the carb?
Old 09-06-2015, 07:10 PM
popcorn13's Avatar
popcorn13
popcorn13 is offline
Talking
when i took mine otta storage it would only crank over. thanks to all the help here i replaced the crank sensor and she fired right up. thanks men.
rstrydio
03-22-2014 07:02 PM
s.ga.rider
Exhaust System Topics
06-13-2012 03:03 PM
jgibson79
06-18-2011 11:08 PM
mucklepilly
04-09-2010 08:54 AM
albionphill
Panhead
10-19-2007 02:26 PM
Quick Reply: my sftl twin cam backfired & now won't start
