Drive Belt Durability?
Had a buddy break a drive belt this past weekend while at the Hot Springs Rally. His bike is a CVO RG w/ 110 with extra performance mods.
Another buddy and I were talking about it and he just went on about how that belt won't hold up to that extra power.
Just wondering at what point in performance upgrades do you need to do something different than the belt? Anyone here have that problem to? and about where in the HP/TQ numbers do you think the belt needs to go?
Drive belts do fail. Improperly adjusted, or damage caused from rocks trapped between the belt and pulley are frequent culprits. A small hole in the center of the belt usually isn't cause for alarm, but visible damage to the edge of the belt is a sure sign the belt will need to be replaced.
I have the S&S 106 kit with 10:1 compression and have not had a problem with my belt and currently have just over 43,000 miles
"Properly Adjusted" is the key. If you or the Technician that's working on the bike isn't using the "Harley Tension Tester Tool" Harley Part Number 40006-85 I can absolutely, positively, guarantee you; that it isn't being adjusted correctly. The Tool lists for like $35 but can be bought on eBay for $22-$23. There isn't any excuse for not doing it correctly.
