Trans fluid leak
Trans fluid leak
Got my 95 FLH back from the dealer shop last week from having a transmission fluid leak fixed. The tech said it was definitely the shifter shaft. $250 some odd bucks later she was supposedly fixed.
Rode the bike about an hour today (first chance since getting her home due to monsoon). She is leaking more than before. Trans fluid on inner primary below rear pulley.
My opinion is that the trans output seal or the seal between the inner and outer shaft is leaking.
My thought is that all of that should have been checked and probably replaced as a matter of course while everything in the primary was apart. I waited practically all summer to get this done (shop busy) and it rips me to think I may have to sit out the fall mountain ride we do this time of year.
I'm taking it back tomorrow or Thursday and getting them to look at it. I feel that they owe me to fix it properly, and promptly. I don't mind paying for additional seals etc and some additional labor but I definitely don't think I should pay the whole tab for the teardown and reassembly and dont think I should have to get at the back of the line again. Just asking them to make it right.
I am a regular customer and bought a new bike (Dyna Low) from them in June. Am I being unreasonable?
I agree with the OP. They should have looked at the transmission output shaft seal while they had the complete primary off. In my opinion the dealer should eat ALL labor to get the bike back to the point where the primary is completely removed and then start charging labor and parts to get to the trans seal and R&R it. Re-assembly labor should stop at the point where the primary is re-installed as he's already paid for it.
I agree, but what I will say is to properly replace the shifter shaft seal the shifter pawl should have been removed. Which requires removing the gear set. Most shops charge 6-8 hours to do this and most Harley dealers are charging about $100 an hour.
If you want to pound it in over the shaft at least lube the I.D. of the seal and the shaft so you don't fold the lip over or tear it. But yea, "while you're in there" replace all the seals and gaskets. Pulley spacer too.
I've had good luck cleaning and lubing the shift shaft and slipping it on. I know it's not the right way to do it and one day it'll bite me, then I'll have to remove the entire primary drive again.
Mark,
How much trans fluid can you lose out of a leaking shifter shaft seal provided you check it?
Mark,
