Oil Pump shot how do I test?
Old 10-11-2015, 01:08 PM
Wi_Duker's Avatar
Wi_Duker
Wi_Duker is offline
Originally Posted by Iron lHorse
I think it mite be a good time to install a oil psi gauge to see what the psi is.
I'm going to say zero.
Oil flows into the tank but not out of it
Can anyone explain to me where the oil goes after it comes from the tank and goes thru the pump?
On a diagram it looks like it goes from the pump to the filter back to the pump
Old 10-11-2015, 02:49 PM
Wi_Duker's Avatar
Wi_Duker
Wi_Duker is offline
Changed filter after seeing that oil made it to it. Changed oil.
Now I have oil flow.
Now I just have to deal with the ignition module cutting out when it reaches 220 degrees
Old 10-11-2015, 02:55 PM
Tommy C's Avatar
Tommy C
Tommy C is offline
Received 19,674 Likes on 6,683 Posts
I would seriously think about putting an oil cooler on that Sportster, OP. Those kind of oil temps you have are gonna kill that thing.
Old 10-11-2015, 03:01 PM
Wi_Duker's Avatar
Wi_Duker
Wi_Duker is offline
Vendors say 200-250 is normal for a 1250
Old 10-11-2015, 03:55 PM
Tommy C's Avatar
Tommy C
Tommy C is offline
250 is too hot. Oil oxidizes & viscosity breaks down @250. I don't like anything over 235. I would put a cooler on it- it'll be cheaper in the long run when you factor in the wear & tear from excess oil temperatures......
Old 10-11-2015, 04:38 PM
Wi_Duker's Avatar
Wi_Duker
Wi_Duker is offline
I think I will agree with you on this
Old 10-11-2015, 06:15 PM
tmanbuckhunter's Avatar
tmanbuckhunter
tmanbuckhunter is offline
Looks like you found your problem... a clogged oil filter. I was going to mention that maybe you lost a bearing and a needle made it into the scavenger gears, but that is worst case scenario. Everything else is good right?
Old 10-11-2015, 06:54 PM
Wi_Duker's Avatar
Wi_Duker
Wi_Duker is offline
no idea. the ignition module cuts out when it gets to 220 degrees
Old 10-11-2015, 07:23 PM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
Is that oil in the tank?
Looks like sludge.
Old 10-11-2015, 07:54 PM
dyna rider's Avatar
dyna rider
dyna rider is offline
Default Oil Change
Change the oil and put on a new filter and check it then...
Quick Reply: Oil Pump shot how do I test?
