Oil Pump shot how do I test?
Old 10-11-2015, 07:08 AM
Wi_Duker's Avatar
Wi_Duker
Wi_Duker is offline
Default Oil Pump shot how do I test?
It's like it never ends.
On the highway today. Bike was running great. And suddenly I cut out like it was out of gas.
On the side of the road looked down and my oil temp was 350 or more. No oil pressure light on, no smoke, nothing coming out of the tail pipe.
Rented a uhaul and got it back home.
What I have found so far. The plugs are dry no oil. the oil tank is full, and by full I mean there is more oil in it than there should be.
This is weird. I compression tested the front cylinder and got 240 psi. Normally it is 185.
I cant run more tests on it because the battery is drained and I am waiting for the battery charger to charge up.
The status light on my ignition module doesn't blink red, but will register TDC
What should I be looking for? Where do I start?
Info on the bike.
1988 sportster 1250
Daytona twin tec ignition
Old 10-11-2015, 07:20 AM
Iron lHorse's Avatar
Iron lHorse
Iron lHorse is offline
Received 2,374 Likes on 1,161 Posts
Info on the bike.
1988 sportster 1250
Could be a plugged suction hole at the bottom of you oil tank , a badly clogged oil filter , a kink in a oil hose , a broken spring in your oil bypass valve .
Old 10-11-2015, 07:39 AM
Wi_Duker's Avatar
Wi_Duker
Wi_Duker is offline
Compression test front and rear 210 psi
Started bike for 30 seconds oil appears to flow in but doesn't appear to flow out
Old 10-11-2015, 08:10 AM
Wi_Duker's Avatar
Wi_Duker
Wi_Duker is offline
Thanks
Old 10-11-2015, 09:06 AM
Wi_Duker's Avatar
Wi_Duker
Wi_Duker is offline
Drained Oil, checked for blockages in outlet and vent hose, put on new filter, only put in a quart of oil.
Oil Flows into tank, doesn't flow out of tank
Old 10-11-2015, 11:57 AM
tmanbuckhunter's Avatar
tmanbuckhunter
tmanbuckhunter is offline
Does a sporty have scavenger gears like the pump on pre- 2cam big twins? Shovel, evo, etc...
Old 10-11-2015, 12:04 PM
Wi_Duker's Avatar
Wi_Duker
Wi_Duker is offline
Yes it does
Old 10-11-2015, 12:07 PM
128auto's Avatar
128auto
128auto is offline
Do you use synthetic oil? My 107ci oil pressure 42psi at idle cold, 2psi when temp hits 250f. That's why you use synthetic, oil starts breaking down at 250.
Old 10-11-2015, 12:13 PM
Wi_Duker's Avatar
Wi_Duker
Wi_Duker is offline
Oil will flow into the tank But will not feed from the tank into the engine.
Somewhere along the feed route either into the pump, to the oil filter or from the filter back to the pump is a blockage or lack of pressure. Oil flow from the pump to the tank is strong. From the tank Nothing
Old 10-11-2015, 12:17 PM
Iron lHorse
I think it mite be a good time to install a oil psi gauge to see what the psi is.
Quick Reply: Oil Pump shot how do I test?
