Changing foot and shifter pegs. Can't get the existing shifter peg (HD part no. 49149-84A)off from the shifter arm. The peg has a cover plate that hides the head of the bolt. Can't get the cover plate off. Any suggestions?
If you are not interested in keeping it, just cram a screw driver bade in between the peg end and the cap. The caps I have seen are just a press in to the allen socket.
Been trying that. Trying to cram a razor blade into it doesn't work.
You run an ice pick size pick in the middle and rip it out. Junk. One time use.
Then buy a whole pack, a sheet of new ones for under 15 bucks on Amazon.
those bolt cap covers usually just press on.. if you not saving it. a pr of pliers or channel- locks will do it if you can't get a screwdriver between them..
Maybe a picture would help us see what your into...
