Keeping Warm: Heated Gloves vs. Heated Grips
The colder mornings are starting to fall in to place here in the Northeast. Prior to purchasing my FXDL this past June I owned a Honda Shadow Phantom. I bought hat in May 2014 and road it through the winter months as long as it was at least 35 degrees(except mid Feb and March when we got hit with a ton of snow). I added a windshield and I purchased Gerbing's T5 Hybrid gloves to help with the cold weather.
The gloves worked as advertised. With the controller they heated as little or as much as anyone could need. However at times they seem to create an opposite affect. Eventually my hands would start sweating and the cold air coming at me made that sweat cold which in turn pretty much left my hands cold anyway. I ended up selling them to a fine forum member here only because I was not a fan of the Gauntlet style. I am short and pudgy so my jacket sleeves are longer and bunch up which make the fit of the gauntlet a pain.
The plan was to purchase Gerbing's new glove that has knuckle protectors and is not a gauntlet style. They just were released and are around $200. To try and avoid it I purchased the National Cycles clear hand guards in hopes it would take enough wind off of my hands to get away with standard winter moto gloves. I am disappointed in the results. They don't look bad on the bike with my MS El Paso windshield and they do cut down on some wind, but not enough. This morning was about 45 degrees and after my 65 mile commute my hands were pretty darn cold.
I started thinking about putting that $200 toward some heated grips instead. I'd need to have them installed because I am not there mechanically yet so my guess is that will add at least another $100 to the cost of the grips. I figure it will be close to $400 when all is said and done.
I'm looking for opinions on your experience between the two. Do you like heated grips or heated gloves better?
I ride all winter so there's a learning curve you need to go thru to find what works for you. I've had both heated grips and gloves. I liked the grips as they were easy to use and my hands were always warm, both sides. The gloves also work good no complaints. But Sometimes you just don't need the heat, so what I did was buy a set of plastic wind deflecters that mount under the nut for the mirrors. They deflect alot of air off your hands so at times you may not need the heat on, if you have good gloves. In the spring I take them off, takes 5 minutes. As we say in the Polar Bear club dress to be warm, this ain't no beauty contest.,,,
I ride all year round and IMO, heated gloves with a controller is the way to go. Without a controller/thermostat, you're stuck on HIGH heat and that can get uncomfortable, as you know. I have Gerbings T5 gloves with a dual controller (heated boot liners) and have ridden in 8 degree temps with no problem. DEFINITELY need a controller/thermostat.
Unlike the above poster, keeping my feet & hands warm is the key to keeping the rest of my body warm. NEVER needed or even thought about a heated jacket or pants, because they just aren't necessary.
Believe it or not also take a look at a heated jacket liner. I was amazed at how warm my feet and hands stayed when I kept my core warm. It works so well that I don't even get my heated gloves out until the air temp get down in the 20s.
Just something you might want to consider.
I would recommended the aftermarket heated grips where the heater element goes into the handlebars NOT the HD heated grips. They are about $170 at my local dealer plus 2 hours labor to install (~190).
