? Keeping bike Outdoors over Winter Tn.
Received 1,934 Likes
High winds are your enemy and will destroy finishes or even small parts under a loose fitting tarp or cover in a very short time. You can't buy a wax or protectant that will offset this.
A hard shelter is best, followed by a rigid frame & soft cover or lastly a plain soft cover that fits perfectly (no flapping ).
Cheers,Graham.
http://www.uline.ca/BL_2414/Marine-I...Q&gclsrc=aw.ds
has become popular up here as a cheap solution for outside storage of boats. Other systems involving aluminum frames and custom tarps work too but don't last forever and are expensive.
In all honesty bro, inside is the safest place if you have any concerns about strong wind. The first winter I owned my Breakout, I was in the same situation as you and put the bike in a self storage unit, which I shared with another biker, for the winter. Its costly but safe and a great idea if you have other items needing storage or can find another biker willing to share space and cost..
I don't mean to play chicken little with this. Its not impossible to store outside under a cover, and as Nomadmax points out, Canadian winters are exceptionally severe . If you do your double cover thing, just find as sheltered a location as possible and maybe use a system of cargo straps or something to keep the outer cover from buffeting against the inner cover or bike. Its just important for you to be aware that wind is a primary issue to be dealt with and to not ignore it.
Received 4,895 Likes
I agree with all suggestions above. Assuming you will have to go with outdoors, just a suggestion for the chrome. A buddy of ours had to do the same thing a long time ago in my Father's backyard. He bought a huge jar a Vaseline and put a thick coat of it on all of the chrome, ALL of it. Took an afternoon to get it off in the Spring but all of his chrome survived a NYC winter with zero issues. Good luck.
Selling it would be easier,but then i have to find a buyer.
Cheers,Graham.
Received 47,744 Likes
