110 engine swap
Old 10-26-2015, 10:33 AM
Joel1254's Avatar
Joel1254
Joel1254 is offline
Stage I
Default 110 engine swap
I have a guy with a 2010 110 harley engine to sell. It is out of a touring bike. I have have a 2006 dyna with a screaming eagle pro tuner ut came with a six speed trans. This 110 comes with throttle body and injectors, he even had the primary cases and Trans if I want them but they are from a bagger, I just need your guys input. Will this engine swap right out for my 95ci?
Old 10-26-2015, 10:38 AM
Roadflyer's Avatar
Roadflyer
Roadflyer is offline
I think the 2010 is Throttle by wire and your bike is not.
Other than that, I think everything else is a go.
I'm sure other folks that know a lot more than me will chime in.
Old 10-26-2015, 03:48 PM
OldEnuf2NoBtr's Avatar
OldEnuf2NoBtr
OldEnuf2NoBtr is offline
Received 1,811 Likes on 1,064 Posts
Yeah, you'll have to change out the throttle set-up for your bike but that's not all that difficult nor expensive to do. H-D sells what you'll need to make the change over. You'll also need a new ECU unit I believe.
Old 10-26-2015, 04:18 PM
dickey's Avatar
dickey
dickey is offline
Received 5,479 Likes on 2,478 Posts
No; a touring motor & a Dyna motor are NOT interchangeable.
You can tell just from looking at the primary; it will not bolt up to the tranny.
Old 10-26-2015, 05:28 PM
oct1949's Avatar
oct1949
oct1949 is offline
IMO... just save you """$$$"" and do some Cams and headwork that matches your riding Style on you 96''er and you'll outrun most all 110's in stock form and keep up with any modified 110''...
Old 10-26-2015, 06:40 PM
OldEnuf2NoBtr
But................... Aren't both the Touring and Dyna motors both the (A) designation with the Softail being the (B)? That's what I've always been lead to believe.
Old 10-26-2015, 07:17 PM
lh4x4's Avatar
lh4x4
lh4x4 is offline
The touring front case bolts to the frame in a completely different manner than it does in a
Dyna frame.
Old 10-27-2015, 06:46 AM
Campy Roadie's Avatar
Campy Roadie
Campy Roadie is offline
Received 5,063 Likes on 2,501 Posts
Dyna frame.
The front head is different as well.
Tinmanpope
Engine Mechanical Topics
10-01-2018 06:25 PM
DannyWest
11-09-2012 06:52 PM
Lawrence Mazur
08-11-2012 01:52 PM
iceman5218
07-08-2009 09:42 AM
Hd fanatikz
10-17-2008 04:21 AM
Quick Reply: 110 engine swap
