Remove baked on oil on exhust shield
11-15-2015, 11:56 AM
Any advice. Thank.
11-15-2015, 12:04 PM
WD40 with 0000 Steel wool. Make sure it is 0000!
Easy, no mess. If it's heavy you might need to soak it with a WD40 soaked rag.
Works better than, and less mess than other recommendation such as oven cleaner.
11-15-2015, 12:17 PM
11-15-2015, 01:42 PM
try to get copper wool if you can, it is softer than the chrome. You can usually find it at marina's if no where else.
11-15-2015, 01:45 PM
I used denatured alcohol and a cotton swab. Soaked it, let it sit for a few minutes, a little rubbing, and it all came off.
If you don't have any denatured alcohol, 80 proof vodka is 40% alcohol. Plus, it gives you something to do while you let it soak.
11-15-2015, 05:27 PM
Baked on oil on heat shield.
What were you doing, baking 'road kill'?
11-15-2015, 05:29 PM
Spray regular canned Lysol on it, that will remove anything.
11-21-2015, 07:34 PM
Keithhu
10-02-2014 08:41 AM
JT-FXDL
04-07-2012 09:44 PM
slackwolf
Oil Archive (no new posts)
06-30-2011 09:08 PM
My Fix
08-20-2009 04:19 PM
philly_night_train
General Topics/Tech Tips
09-27-2005 09:43 AM
