YAGOQ (Yet Another Gas Octane Question)
I always put 91 Octane gas (highest Octane you can get in Socialist California) in my beloved Harley simply because I want the best for it. The cost difference is a couple of cans of beer; no big deal (at least until I retire).
I live and ride almost entirely on the Coast, at exactly Sea Level, give or take a few hundred feet.
So is there really any point in putting in 91 over 87? I had always thought that more Octane equates to more zippity do-dah in the gas. However, reading up on the subject it appears that the real difference has do do with pre-ignition, which is generally a non-issue at sea level. (?).
A related question. Thanks to our idiot Leaders, gas has that crappy corn alcohol in it, which is bad for all engines. Will 91 tend to have less of that?
Comments appreciated.
Another problem is ethanol's stronger attraction to water than to gas. When as little as 4 teaspoons of water per gallon of gas is absorbed, you can get what is called phase separation. You are then left with the gasoline on top and a water/ethanol mixture on bottom (think Italian dressing).
At the end of the day, most of the issues you hear about with ethanol can be handled with proper fuel management. Being aware of how long it takes to run through gas and trying to keep the fuel tank full when sitting for extended periods of time will certainly go a long way in preventing headaches with your fuel system.
Have a great day!
Higher octane doesn't make the gas "better", the gas itself has absolutely no more power. The octane rating simply determines how resistant the fuel is to pre ignition. I too use premium in my Limited, mainly because that is what the MOCO recommends for it.
Don't know how things are in California, but here in the corn belt our gas all has at least 10% ethanol, has for several decades. That is true for all "grades"- regular, mid and premium. Except where ethanol free fuel is sold- I've only seen ethanol free premium, not sure if the lower octane fuels in MN are offerend ethonol free, I've not see any.
Most if not all engines made in the past couple decades are compatible with gas containing up to 10% ethanol. I'd assume that's what your premium has, unless the pump is labeled otherwise. If the gas has more than 10%, I'd hope the pump would state that, because you don't want to use anything higher than E10 in any engine that isn't rated as flex fuel compatible. Here we can get E15 and E85 at some places, but the pumps are marked, and if you put E85 in a vehicle not rated to burn the stuff, you'll have some trouble on your hands.
Have a great day!
Received 3,988 Likes
