Gear Oil
Gear Oil
Hello all,
Its been awhile and I have another question. First let me tell you I have a 2005 Fatboy 15th anniversary. Nice ride, I've been using the Mobile 1 V-Twin 20W-50 full synthetic in Oil, Trans and 75W-90 in the Gear box. All Changed every 5000 miles. Wanted to know is there something else I can use for the gear box? Seems the shifting is a bit loud (Klunky) and wasn't sure if this is normal. Also if I use something else there is it ok to have different lubes in the seperate areas?
Thanks!
Thanks!
I run Redline Shockproof Heavy in my transmission, Mobil 1 15w50 in the engine, and regular Pennzoil 10w40 in my primary. Have done this for years. I change the engine and primary every 5k miles, but only change the transmission every 10k. However, many transmission fluid mfg's indicate you can run their fluid up to 20k miles.
