Front ABS brake bleeding
Does anyone know if this is a fairly straightforward procedure?
My mate wants to fit some mini apes, however, our local Indy says bleeding the abs is a complex procedure. He's quoted £450 ($675) to supply the cables, brake line, extended wiring and fit my mates own bars. They're not internally wired. Seems a lot for this job!
Its not complicated till you get air in the Module. The method I use after a bar swap that includes the mc line to the module, is to push the fluid up from a front caliper. I use a full syringe with a plastic hose void of all air connected to the bleeder, push new fluid up to the mc with the syringe. Using this method never allows any air into the module. This method also makes no mess so long as you do not overfill the mc.
