I've been thinking about putting True Dual on my Fatboy however due to the heat on the left leg i'm going to put Ceramic Coating on the pipes. If done properly is it true you can touch the pipes after 30 minutes of riding and it will be warm but not hot to the touch?
How about Heat Wrap, how effective will that be?
I'd go ceramic if I were going to do it. Wrap looks nice at first, but I'm not a fan of how it looks after some time.
Maybe the method of installation of the wrap makes a difference in appearance over time??
I highly doubt that ceramic coated pipes run cool enough to touch while riding. Probably ok for a quick touch, but probably not with prolonged contact. I'd love to believe that though. Somebody please advise if you know otherwise. It would help justify the expense of having it done. I was quoted $300 to coat my little 2 into 1 header pipe, so I went the cheap route of exhaust wrap. Even with the wrap, if your pant leg is in prolonged contact with a section of exhaust, it will burn. So I'm using wrap with heat shields. The combo does work great now, but yeah, the appearance of the wrap does go to crap over time. It's also been said that wrap will cause your pipes to brittle & crack. Other say as long as the pipes & wrap aren't exposed to dampness, it wouldn't be an issue. I personally think ceramic coating with the use of heat shields would be ideal.
Let me know when you're going to experiment with touching the pipes after 30 minutes of riding so I can be there with a camera to film it. I haven't posted anything funny to You-tube in a while!
Not hi jacking a thread but.. If a guy is in business doing powder coating. Is it safe to assume he can ceramic coat stuff too?
Not from what I experience when calling around. I was checking on both, Powder & Ceramic. I didn't find any shops that offered both. In fact I found local Powder Coat companies all over the place. But very few companies to offer Ceramic Coating. Which is another turn-off for me. Nearest is about 1.5 hours away.
ceramic coating works quite well if done inside & out. pipes will be cool enough to touch abt. 20 minutes after shutting down your bike. had a set of triumph pipes done awhile back, turned out great.
Heat wraps are good if you want that "held together by rust" look. They hold in the moisture, maximising the potential for rust. Also collect all the road grime without the ability to clean it out, for a true "rat bike" look. Is that what you're going for?
