Seals In Primary
Seals In Primary
I need some help, I am going to retorque the compensator nut on my 03 Fatboy.
While I'm in the primary I want to replace the starter jack shaft seal and the shifter seal. Looks pretty straight forward but my concern is the fact that I have a hydraulic clutch on the bike. If I pull the compensator and clutch basket as an assembly can I reinstall them without having to do anything with the clutch adjustment? Also does the push rod stay in or can I remove it from the primary side and reinstall it after the seals are changed. Looks like it is locked in on the other end with a retainer ring. Thanks for your help
clutch will not have anything to do with what you want to do. Remove the circlip from inside the clutch hub, and extract the brg and the rod all in one piece. You have to do that to get to the nut in the clutch basket. Don't forget that its an opposite thread! When you get it all back together, slide the rod and brg back inside the clutch hub. you will notice two ears on the brg, and they fit into the hub, reinstall the circlip and you are done. no clutch adjustment needed. hope that answers you question
to install all the seals you are talking about, you might just pull the inner primary off, the compensator is in a few pieces, depending on the one you have. You can pull the clutch hub off as one piece, but the comp will have to come out in pieces. make sure you have the shop manual. Also I don't know why you want to retighten the nut for the comp. are you suspecting its loose?
I understand, but In my line of work (a tech for Mercedes)I go by the rule: if its working don't fix it. Yes the shift shaft seal leaks, is yours? are you getting a lot of clunking in the primary area? take the outer off, and just see if its loose, if not button it back up, you're out a gasket and some fluid, if it is, then go for it. If your seal is leaking, then you will reseal everything, and its more involved. just be wise in your judgment.
he mentioned in the beginning that he has a hydraulic clutch, so no adjustment.
Sure you can relate. I'm a technician and work on transmitters, controllers, and actuators. By policy we are required to operate and inspect at various interval - totally justified and logical. Annually we are required to disassemble, completely calibrate, and test all parameters. This is the equivalent of rebuilding an engine with 15K on it.
Yes I'll inspect, test, and record results, but after 40 years I'll be damned if I'll tear down a perfectly good anything - all I could do is create an issue not there, not improve it.
