Memphis Shades problem
I've got one of the Memphis Shades windshields with Gradient Black tint on the lower portion.
I noticed that over the last month or so almost the entire tinted lower section has gradually crazed over with very tiny "stress cracks." The upper clear section is fine. Anybody else had this problem? I've emailed Memphis Shades but haven't heard back yet.
HarleyDan07 (10-19-2019)
Are you using a glass cleaner on it like Windex?
Another thought is for guys that use a cover in high temps.
The crazing is a common issue amongst boaters with wind shields. Usually an alcohol based cleaner is used or extreme heat from sun are the culprits
Received 32,874 Likes
Nope, don't use anything other than soap and water on the shield then dry it with a soft towel. Mine also is only doing it on the tinted lower part. No problem with the clear upper.
MS e'd me back and there is a two year warranty on the shield. When I get home I have to send them the lot number of the part and they will check it out. I hope the place I bought it from didn't have it sitting on the shelf for a couple of years.
If they don't make good on it I'll still use the shield. Like RHPAW said, I'll just stop caring about it.
RMcCord (10-19-2019)
Nope, don't use anything other than soap and water on the shield then dry it with a soft towel. Mine also is only doing it on the tinted lower part. No problem with the clear upper. Unfortunately down here in FLA it's hard to avoid the sun and heat though.
