Lifters Tappets what do you recommend?
I am doing the tensioners on 2000 TC88. Bought this a few years ago as a garage queen with 6000 miles on the clock, coming up on 30 now. Looks and runs like it should for the miles but being used you never really know.
Decided to go in through the top and take a while in there approach. She runs fine but is 16 years old. I am doing the 07 plate, new and improved oil pump, with Andrews 21s. Updating the breathers to 20111style, installing a set of Rockouts, B-148s, all gaskets, O-rings and the lifters. No plans to go to a 95, just looking for solid reliability. Because I am not planning to use adjustable push rods, I hope to not have to go back in here for a while.
By the way, the outer tensioner was about half gone and the inner was really toast, almost in metal. I barely touched the outer and it broke off, I think in addition to poor design, these get brittle with age.
Now the lifters. I assume mine are straight 18538-99, they show a little scoring but have been quiet and fine. I have read where they have changed through A, B and now on C. I also read where the B seemed to be great and very reliable while C seem to be problematic and noisy.
I also read where some are using Melling, Comp Cam, V-Thunder, Clevite, AMS Johnson, S&S. and small block Chevy.
I am not a cheap a$$ but dont want to spend money where I dont need to either.
Anyone have experience with any of these, or what do you use?
Thanks.
Thanks.
I reeeeaaallly doubt that Harley makes their own lifters. I installed new OEM Harley lifters when I did my build. I assumed they were made by a tier 1 OEM auto supplier but who knows, maybe they're cheapin' out now. I suppose S&S would be my first choice for aftermarket lifters. What part of the newer Harley lifters is going bad?
Fueling Lifters
Used HD hydraulic kit and went with Fueling lifters. He's been in business over 30 years and does know a thing or two - fwiw. Also, nice having oil pressure at hot idle now.
Back when I worked for a living, we aged harden delrin for mask bearings for sub periscopes. Hot oil depending on time and temperature will make delrin brittle but tougher. I agree. Inspect link chain tensioners at 30K noteing wear and plan from there. Replace no mater what at 10 years or if you have to pay someone to inspect.
Received 19,611 Likes
