Stage 4 103 and FP3
You guys don't understand how the FP3 works. Even when you go in for a dyno, you are starting with a map in your ECM, and they flash that map after tuning.
The FP3 is NOT an inline tuner, always connected to "fool" your ECM. It is more closely related to the SE race tuner, not giving you as much tuning flexibility, but also costing less than half as much.
Actually if you leave it plugged in and do an auto tune, it will learn your perameters. All you have to do is use this tune as your download. If you have access to a dyno, or dyno operator you can dyno tune it in auto tune more accurately. It requires X amount of time each gear and throttle position to properly auto tune.
Yes, I know, I used one on my bike. You have to leave it connected in order to "learn" how your bike operates. Once it's collected enough data, then you tell it to tune, which is when it re-flashes. Once you re-flash, it's up to you if you want to leave it connected or not. While connected you can view many different pieces of operating information via your phone app.
Yes, a dyno and something like the SE super tuner will give you a finer tune, but I doubt that most would notice the difference except for on a track.
Z
06-17-2019 01:12 AM
