Dot 4 brake fluid
Brake Fluid sources
Only about 3 companies in US make brake fluid. Marketers buy in bulk from them and package it. Federal Motor Vehicle Safety Standard 116 sets minimum wet and dry boiling points for each DOT grade. Typically, the higher the better for boiling points, just remember never to mix DOT 4 with DOT 5. The silicone-based DOT 5 is never compatible with DOT 4.
Viscosity can also vary a bit. Low viscosity is usually specified for ABS systems because the lower viscosity fluids allow for rapid feedback through the ABS system.
In general, buy the grade fluid recommended by your OEM and it's tough to go wrong.
