Need some help please
I have a plug & play question. My bike is a 2014 ultra limited with the new wiring system and I have added the plug & play saddlebag lights ( brake,tail & turn ) and now I need to add the plug & play trailer wiring. My question is, has anyone added two plug & plays in series from the same plug under the seat and if so did it include a trailer plug & play. I think I may be able to add the two but not sure if it will over load the rear light circuit. Trailer has LED's also. Thanks in advance for your help.
So did you plug both plugs in series in the same existing harness. One end of the FIRST plug'n play to the existing harness then the other end of the FIRST plug'n play to one end of the SECOND plug'n play and then the other end of the SECOND plug'n pay back into the existing harness ?? Just trying to make sure you can run these in series in the same existing harness.
Lonely Drifter on a Harley Breakout
04-18-2017 11:58 AM
Porgey
Electrical/Lighting/Alarm
06-21-2015 05:50 PM
