Drive Belt Tension
Drive Belt Tension
For some reason HD has loosened up the specs. on the later model drive belts. What do you guys do that have earlier models, like say in the early 2000's, do you go by the specs in the owners manual or did you decide to loosen the belt up to the newer specs ?
Thanks Jonnierock
Thanks Jonnierock
Received 4,146 Likes
Keep her on the loose end myself too.
Important thing is to get a good belt, and have it lined up properly. It's just a belt...there's not much myth and folklore magic about it...good quality belt and proper alignment is what counts. Too tight...obviously strains it. Mid-aligned...obviously strains things too.
I like Gates Kevlar ones
