Lights in the speedo.,,,
I thought that if the CEL and key light come one after starting, you have a stored code. Also, check your fob battery (if you have one). I think it can do that if the fob battery is weak. I could be wrong for both.
Routinely, once my CEL turns off from initial ignition on, it does not come back on. As long as my fob is present, my key light does not come on at all, or if at start up, it goes out quick.
I wondered this myself when I first got my bike.
I thought the question was going to be about the light not coming on until it gets dark. I've covered my speedometer to get it to come on when it was semi dark. My last bike was the same way. I first noticed it, when I pulled into the carport late one day and it came on.
Received 14,163 Likes
Then again I ride a carbureted Evo.
Mine is also light sensor'd. The logic I see in it, is to save bulb life. The light is not needed when it is full daylight outside. Since the headlight is on all the time, it can't be turned on and off with the headlights like in a car. I think it's pretty damn smart of them.
