H-d upgrade 103 to 113???
Did a search here for "113" and nothing new or special came up and did the same on H-D.com and nothing came up.
Anyhow, on my way home from Daytona I went by my dealer and he had a new 2016 RGS on the showroom floor with supposedly (according to the salesman) a H-D factory upgrade on the 103 to a 113. The primary cover had a big "113" on it and there was a printed "CNC Heads" also on the engine. I don't recall reading anything on this forum about it and was just looking for info.
The 113 upgrade has been around for several years. It is the 4.060" bigger bore cylinders and pistons, on a 4 3/8 stroke bottom end, as used in the TC96/103/110 . It's the same bore as used in the 120r motors, which has a 4-5/8 stroke. You need to have the cases bored for the larger spigots.
The new 117 upgrade is the 4.125 bore, set up as a bolt on for 110 motors, and requires no case boring in that application.
I've got a set of 113 cylinders and pistons sitting on the shelf in my shop, along with the CNC ported matching heads. Set up at about 10.5 compression, it's a good motor for a heavy touring bike.
OldEnuf2NoBtr (03-10-2016)
