Taller gear kit
What exactly do you mean by "taller gearing" ?
The only thing that changing the primary or secondary ratio is going to do is shift the power band of all of your transmission gears to the left or right.
If you want a taller gearing in 1st and 2nd while keeping the rest the same, then you need to change the actual gears in the transmission.
