SE Hybrid Cam Plate and High Flow Oil Pump
I have an 08 road king with the new Stage 5 tire shredder 110 bolt on kit had everything put on as it came from the MoCo except went to SE585 cams was told I should upgrade to the new cam plate and oil pump but than also told by other people the factory one is fine any information would be great dont wanna spend the money if not needed i did upgrade to the fueling race lifters and adj pushrods also considering SE roller rockers
The stock camplate and oil pump will work just fine if they are in good condition.
Nostradamus74
04-15-2018 05:12 PM
