GoPro Wind Noise: Which housing is best?
Just bought my first GoPro and thought I'd share with you guys a test I did to see which configuration gives the best sound.
If you're interested, I made a video so you can here the different housings and what they sound like:
The housings tested were:
My personal opinion on each:
The problem with the Frame, of course, is that the GoPro is completely exposed. If there's even a chance of rain, you're best to put it away or to change housings.
For me personally, I'll probably use The Frame with Wind Slayer 99% of the time, and keep the waterproof housing handy in case of rain.
Hopefully I get some interesting video to share with you guys!
- Standard housing with standard door (i.e. fully waterproof)
- Standard housing with skeleton door (supposed to give better sound at low/medium speeds)
- "The Frame" mount (supposed to be the best sound at low/medium speeds, but the GoPro is completely exposed to the elements)
- "The Frame" mount with the "Wind Slayer" foam wind sock (supposed to cut down wind noise)
- The standard housing with standard door does a decent job of reducing wind noise, but the sound is a bit muffled and there seems to be an odd rattling noise.
- The standard housing with skeleton door allows you to hear more of the bass/rumble of the exhaust, but the wind noise is quite noticeable around 60mph+
- The "Frame" sound awesome, but the wind noise is too much above 30mph.
- The "Frame" with the "Wind Slayer" is hands down the best. Very little wind noise, lots of exhaust noise.
I use a small microphone that you get when you buy a pc. I run it to the rear fender behind the seat. Cured 99% of the wind noise.Also picks up the exhaust sound very nicely.
I don't have a picture of it's current position behind the seat but here's where I first mounted it. It worked very well there, just works better on top of the rear fender, behind the seat.
bbest (04-09-2016)
Sharing the videos is optional, but why not? Someone might get some enjoyment out of them.
This all depends on what you intend to do with all of this. Personally, I started out using an external mic wired into the go pro with the adapter, and the mic was in my helmet. No wind noise, and it don't matter what housing you use. I don't use a face shield on my full face helmet anyway. The best option was to get my SENA bluetooth backpack setup, again the mic is inside the helmet. The added benefit of all of this is you can talk man! TALK! Sounds like you are in the good makings for some motorvlogs! You can still hear the rumble of your bike with the mic in the helmet, but that can always be a tradeoff, with wind noise.
Nothing wrong with that, and yes, you will be surprised how many people watch them.
Windseeker
Harley Davidson Videos
09-01-2022 07:16 AM
BobRR
03-15-2019 08:18 AM
wildcat465
09-21-2008 09:43 PM
