Can't get my throttle all open
OK so I bought a 01 wide glide that has 14 inch apes on it and it also has a mikuni carb on it .... I had a idle cable pop the other day I thought no big deal I'll order the cable and just replace both while I'm doing it. After I got the cables delivered and changed out everything felt good I got on the road and I can not get enough throttle and I don't know what was changed to give me this problem. Thank you so much for any help or anyone that has had a similar problem
Received 19,654 Likes
Mxdad (04-29-2016)
I agree Tommy I've done that it's got the right amount of play the idle cable is returning properly it's just not opening all the way.... being the seconday owner Ivery had a hard time with technicians because even though I know it's an aftermarket carb I can't find the correct model of it would there be different cables that the carb would make different... the lengths are the same and it fits into everything right
