idle problems
carb came from a good harley mechanic so is jetted properly just going to recheck for manifold leaks bike sounds way better than it did with a super e on it. my next task will probably be loosening off the heads and aligning intake manifold to heads then tighten heads if this does not work next step will be getting valves checked. this is my first harley after riding triumphs for years so am learning how to do stuff the harley way
So after changing the wide band securing the adapter to the intake ports on both cylinders to 2 skinny bands then getting rid of the NGK plugs to Champions bike started up and ran like a totally different bike,no hesitation,no powerloss,or stumbling for about 15-20 minutes then while sitting at red lights there was light blue-grey smoke coming out the exhaust pipers,when i picked up the rpms the smoking stopped until the next red light when it started up again so needless to say i am totally baffled again. Thoughts anyone as this can't be blamed on being my first Harley as even if it had happened on any of the british bikes i rode over the years i would have been as stumped as i am right now
the required jetting can not always be determined by a bench setup. There is such a thing as ballpark jetting but each bike has its own requirements. The variables in manufacturing, state of engine seal, atmospheric conditions, all effect jetting requirements. If i had to guess Id say that you eliminated or minimized an air leak at the manifold with the switching of clamps. Small air leaks like these will have a larger effect on idle and small throttle openings. At the point your at now id be looking at first the mixture screw, and secondly the pilot jet. This is AFTER of course you've compression or leak down tested each cylinder. Good luck.
Received 19,643 Likes
As others have stated blue smoke is burning oil. There are a number of issues that could cause this. Valve seals, blocked oil return passages, blocked crankcase vent, piston rings, and other things. Depending on the mileage, type of usage, amount of time that the bike sat, it could be really simple. If you can't figure it out we're going to need more info.
