Cooling off after a ride
Old 06-10-2016, 02:10 PM
Mr.Bluster's Avatar
Mr.Bluster
Mr.Bluster is offline
Default Cooling off after a ride
My Harley, like most, is air-cooled. That requires air to flow over the cooling fins. Pulling into the garage after a ride with oil temps in the 220-degree range, seems a good idea to aim a floor fan at the engine, so I do. Anyone else?
Old 06-10-2016, 02:38 PM
Arizona's Avatar
Arizona
Arizona is offline
Nope I've not worried about it and had no issues. The 220* temp is just fine. Ride and enjoy!
Old 06-10-2016, 02:42 PM
SBRob's Avatar
SBRob
SBRob is offline
Received 4,049 Likes on 1,627 Posts
Nope...no need to.
Old 06-10-2016, 02:56 PM
ChickinOnaChain's Avatar
ChickinOnaChain
ChickinOnaChain is offline
Big Kahuna HDF Member
Received 3,070 Likes on 2,554 Posts
I have a carport, so mine is basically outside all of the time. I do wait fir it to cool off before I cover it up. But even when I had a garage, I never turned a fan on it.
Old 06-10-2016, 02:59 PM
dyna rider's Avatar
dyna rider
dyna rider is offline
Default Harley Fan
Sometimes in the heat of the summer I will aim a fan on the bike especially if I want to do something to it after a ride. It can't hurt but I don't do it all the time and have not had issues.
TinCupChalice's Avatar
TinCupChalice
TinCupChalice is offline
Received 8,749 Likes on 3,962 Posts
Just came in from an 87 mile ride in 84° temperatures; the Wide Glide went up on the J&S lift, tender plugged in, and 2 fans were pointed at the engine/primary/transmission. Did you ever actually feel the heat coming off the rockers? I always run fans for an hour or two cooling her off. Why do you think Ward's fans melt if you just shut off the bike without allowing the thermostatic switch to run shutting them off? Those heads are HOT... but of course, YMMV...
Old 06-10-2016, 03:08 PM
kngpn's Avatar
kngpn
kngpn is offline
Received 5,116 Likes on 2,674 Posts
nope, at that point it's not generating any new heat so it will cool on it's own.
Old 06-10-2016, 03:12 PM
Cossack84's Avatar
Cossack84
Cossack84 is offline
The thing doesn't get any hotter while sitting there, waste of time, feel good nonsense.
Old 06-10-2016, 03:15 PM
soft 02's Avatar
soft 02
soft 02 is offline
Received 4,570 Likes on 2,888 Posts
Nope. Dont do it with my lawnmower either.
0maha (06-10-2016)
Old 06-10-2016, 03:16 PM
uklauren's Avatar
uklauren
uklauren is offline
Florida Crew Moderator
Received 3,389 Likes on 1,560 Posts
84 is a cold day here.
Quick Reply: Cooling off after a ride
